What 4 wheel drive do I have?
Old Aug 2, 2008 | 03:42 AM
pearl-drum-man's Avatar
Originally Posted by NewJKInNC
I'll request the build sheet but I'm still a bit confused - My window sticker says 4.10 axle but the transfer case would be something different? And with the 4.10 axle - can I safely assume it's the Roc Trac? I'll post what the build sheet says when I get it - thanks!
Some are confusing the 4.10 axle ratio with the transfer case ratio. Since you have a 2007 auto, you have 4.10 gears in the axles.
As for the transfer case, all X and Saharas have the Command-Trac transfer case, with a 2.72:1 ratio. All Rubicons have the Rock-Trac transfer case, which has a 4.0:1 ratio.
There was an option on the X and Sahara for the rear locker and sway bar disconnect, which is what it sounds like you have. Your Jeep is a good find!
Old Aug 2, 2008 | 03:46 AM
Originally Posted by echofoxtrot
Yeah, what you have is Command-trac II.
Actually he has Command-Trac I, II is on the Liberty only. I don't know why they have so many variable systems to confuse people.
Old Aug 2, 2008 | 07:50 AM
w.wood jeepster's Avatar
What he said.
You've got the true locker, awesome and good gears to start with, double awesome,
Old Aug 2, 2008 | 08:37 AM
jeeperjkj's Avatar
Because if they put the electic transfer case in the JK they'd have a full fledged mutiny on their hands!
Old Aug 2, 2008 | 10:23 AM
RedneckJeep's Avatar
Yes, they were a combined package and one required the other.
Then he has himself a cool X then doesn't he?
Old Aug 2, 2008 | 10:31 AM
Yep, wish mine had the rear locker & disco, then I could just add the D44 front and call it good.
Old Aug 2, 2008 | 01:33 PM
NewJKInNC's Avatar
That's a cool X. It oughtta have the electronic sway bar disconnect, too cause I think the locker and the e disconnect came as a package, did they not?
Yep - it's got the e-disco connect and rear locker switches in the cab - put on my new LoD bumper and winch a couple weeks back - ready to go up to Uwharrie in the next couple of weeks if I can get a free weekend!
Old Aug 2, 2008 | 01:37 PM
NewJKInNC's Avatar
Originally Posted by w.wood jeepster
What he said.
Thanks for all the replies - I think it makes sense now :-) And yes - I think I got a pretty good deal - It was a new 2007 that I purchased new from the dealer in Jan 2008 - I actually traded my 4 door 2wd JK for it - kept the same monthly payments but knocked 1.5 years off the loan because the interest rate I got was much much better than when I bought the 4door 2wd in jan of the prior year!!
