What do stock comtrol arms look like?
Old Oct 4, 2011 | 08:33 PM
19Delta's Avatar
Default What do stock comtrol arms look like?
I just picked up my JKUR a few days ago. I know the lift is a Rubicon Express 3.5". What I DONT know, is if they replaced any of the control arms or just the sprigs.
In the front is has square tubing on the lower, and round on the upper. Exact opposite on the rear.
Anybody know anything?
Old Oct 4, 2011 | 08:52 PM
shockwaveaz's Avatar
post a pic up. Also, in the project jk write-up section, there is a pic in the alignment writeup of the stock arms.
Edit: Never mind, they are not stock.
Sent from my PG86100 using Tapatalk
Old Oct 4, 2011 | 09:47 PM
Runewolf1973's Avatar
The way you describe, it sounds like they are stock. I have a similar setup with the stock control arms, but a 4.5" lift.
Old Oct 4, 2011 | 11:52 PM
nthinuf's Avatar
Check for Cam Bolts. The more expensive kit will have fixed lower arms and adjustable upper arms.
Old Oct 5, 2011 | 05:15 AM
19Delta's Avatar
Here are pics. I don't think it has cam bolts.... atleast I don't see washers on the outside of CA at axle end. It has 37's and drives good.
ID:	219415Click image for larger version
