What happened to my Jeep!
Hey guys, I took my sport to a sandy hill after work today and it just couldn't make it up without getting stuck, I tried 4 lo and 4 high but no cigar. On my last run up i got a little bit more speed (nothing too crazy) before the slope, and ended up spinning in the sand then heard a "clunk" noise and started to roll back down. I was in 4 wheel drive so when I put it in park it made a clunking noise, threw it into drive after backing down the hill only to have it not go anywhere. I thought I popped my front diff so I put it in rear wheel drive and barely made it out. Less than 1000 miles on my baby. Well I went to a dirt lot and tested my 4 hi and 4 lo, low and behold it all seemed to work well, no clunking or anything abnormal. Have any of you guys had this happen? I'm planning to take it this weekend offroading just outside of town to test it out more, but I'm pretty baffled. I didn't think a sport would have so much trouble in sand, especially with rubicon wheels. The incline was a little steep though.
Hard do say what the clunk noise was but as far as your technique...what was your tire air pressure? In sand you need a lot of surface and a good amount of momentum to carry your weight over. Dropping your tires to 15 lbs will make a huge difference in sand.
If you are powering over the hill you should stay in 4H. 4L over 25 mph is a bad idea.
alright
Oh, and welcome to the forum.
Should be 16-18 Psi in sand. Did you roll for a bit after selecting 4wd? BIG mistake people do is STOP ... put it in 4wd and hammer down. This lets the rear tires spin before the transfer case engages the front section of the transfer case. This is usually displayed in a spectacular BANG of engagement and being in sand ... the ill effects albeit reduced can be ugly.
Originally Posted by Jgmz82 OIIIIIO
Yup happened to me also. But I didn't hear the clunk. Pretty scary drop off. Had to air down and get winched out. Haha
Originally Posted by Hijynxxxx
Just wondering.... Did you see the drop before you stopped?
