JK axle change from 2015 to 2016?
I'm a new owner of an '18 JK. I purchased it with some damage, but recently found that the driver side upper C is bent in. In looking at these front axles, I'm seeing aftermarket replacements that are listed as 2007-2018 in year. But when I look up factory replacement, or used replacement, it is showing a cut off around 2016. Is there a difference in say a 2008 and a 2018 JK? The 18 I have has 3.21's in it. I do have a 2008 with both complete 3.73's. The previous owner has already put at least a 3" lift under and it is running 35's. I haven't driven it yet, but I've heard grumblings of the 3.21 being sluggish with this kind of setup.
Also, I will update signature soon with all specs
Thanks
Thanks
There was a minor change through the years on the ears of the yokes in the axle shafts but I don't see why you wouldn't be able to swap the axle without issue. They all use the same sensors. It's a good time to do c gussets and ball joints if you so choose. Also good time to freshen up the u-joints while you've got a little bit of time. Maybe pull the shafts from your current axle and use it in your 'new' axle.
The housings are a bolt in swap from '07 to '18
The axle u-joint change started in late '12.
Sports and Sahara's got the Rubicon size axle yokes.
U-joints switched from 760X to 7166X
New style yokes, DANA SPICER 5-7166X
Utilizes inside "C" Clips to lock u-joint in place.
Dimension A = 2.405 inches
Dimension B = 2.405 inches
Dimension C = 1.188 inches ( 1 3/16 inches )
Dimension D = 1.188 inches ( 1 3/16 inches )
Early style SPICER 5-760X, note the difference in ring retainer groove.
Dimension A = 2.188 inches ( 2 3/16 inches )
Dimension B = 2.188 inches ( 2 3/16 inches )
The difference between the '08 and the '18, is the '08 would take a 760X front axle u-joint, and the '18 would use a 7166X. Externally, all is the same, internally, the older axle shaft had smaller yokes, using the 760X
Jdinny- that's good information. I knew their was a change but I didn't recall all of that. I guess I need to go check my spare axle shafts and see what u-joints are in them. I know I've got the 760's in my current shafts but that doesn't help much if I'm stocking parts for the other shafts.
Also with the yoke change. I believe they slimmed down the heads of the hub bolts too but I don't have old and new part numbers in front of me.
Not so huh? Rubicons are still bigger?
***Update***
In looking the rig over some more, it has Teraflex covers front and rear. It still has a Dana 30 up front, but i did drain and pull the cover to see if it had been re-geared. And it has. It has 4.56's in it. So, I'm not seeing the need for the swap since it's not running the factory 3.21's.
Thanks for all the input. I have other JK's getting put together and the axle/u-joint change is great info.
Thanks
Thanks
