What's behind this panel?
Anyone have pics or a description of whats behind the lower dash panel? I'm thinkin'
it would be a good place for cubby hole. Also thinking of mounting a mp3 holder to it.
[/URL]
Thanks,
x
[/URL]Thanks,
x
That button panel is a part of the center panel. It all comes off as one piece from the radio surround on down. There are four small bolts holding the thing on. You'll see the two at the top when you pull the top panel off and the two at the bottom when you pull off that panel you were first asking about. The heater controls are all attached there so you'll probably want to disconnect all that to work on that lower area. Be careful with those heater control cables, they're not all that sturdy.
Although it appears from the outside that you could do this, once apart you will find that the entire switch bank is one piece. There is a circuit board inside the switch bank that also runs the entire length of the switch panel. It will be easier for you to put switches on that lower panel instead of trying to use that switch bank. Good luck.
Jeff
I totally agree. Use that bottom panel and don't even screw with the middle part.
http://www.cooltechllc.com/ has a nifty replacement lower panel with switches.
