whats the diff in the 09 top to the 10'
On the 10 the top now has a spring loaded cable running through it so that it is easier to put up and down. Also with this they redid the frames above the doors because you no longer need to tuck the top into the frame, just the rear windows get tucked in now.
sounds good. i've only got the hard top right now and would like to get a soft top but every body tells me they are a "pita" guess i'm buyin the 2010 top. wonder about price difference??
Wonder how the new design will affect running a safari or bikini top? On the old setup you tuck the sides into the door frames to keep water out. Sounds like the new frames don't have the lip to tuck in the sides.
10 soft top is a cable top, that is to say instead of having to tuck the canards on top above the doors into the rails, there is a cable there that provides the tension to the rails. I put some pics on myprojectJK if you want to check it out.
