What's the wire to the door for?
Old Aug 6, 2012 | 06:34 AM
Jiblet's Avatar
Originally Posted by ptarnuzzer
Interesting that the dome light and chime are affected by the wire if there are no switches physically located on the door itself...
The latch "knows" if it is open or not.
One way folks leave open their door but kill the door-open chiming is to force the latch to the closed position. (just don't slam the door without re-opening the latch first.) I'd just unplug it....
Old Aug 6, 2012 | 06:51 AM
KY JK's Avatar
The switch is attached to the latch. If you take a screwdriver and close the latch the lights and everything go off even with the doors open. Pull the handle and screwdriver back open and the lights come on.
Old Aug 6, 2012 | 06:58 AM
Redjk777's Avatar
How come the radio stays on with the doors off when I shut off engine.
Old Aug 6, 2012 | 07:13 AM
KY JK's Avatar
If there is no door to open the Jeep power stays on for three minutes or so after the key is turned off. If there was a door to open then the power goes off when its opened.
Old Aug 6, 2012 | 08:26 AM
FlameRedJK's Avatar
It's a jeep thing.
What he said.
Old Aug 6, 2012 | 08:45 AM
ptarnuzzer's Avatar
Originally Posted by FlameRedJK
What he said.
To coin another phrase: "Only in a Jeep!" LOL!
Thanks for all the replaies, and dshing all hope of power mirros!
Old Aug 6, 2012 | 09:11 AM
blw's Avatar
blw
Well, what is the wire for? I have same question. I'd almost consider removing the door card to see where the wire goes...
Old Aug 6, 2012 | 12:38 PM
Jiblet's Avatar
The wire goes to the latch to determine if the latch is open or closed. At minimum it switches the dome light and the radio, if equipped. Rigs with more options get more communication (alarm, power locks and windows, etc.)
Old Aug 6, 2012 | 06:41 PM
Lighting Guy's Avatar
So you can listen to your tunes while you're walking away...
Old Aug 7, 2012 | 08:01 AM
blw's Avatar
blw
Ah, I see. Rather than have a spring loaded switch in the door jam by the hinges they use a sensor in the door latch. That is I presume safer as you need to know if the door is latched, not just closed.
