What's your caster?
Old Aug 25, 2013 | 03:27 PM
tjwrangler2001's Avatar
Default What's your caster?
I won't bore you with all the crap I've gone through wince I bought the JK. It wanders and I think it doesn't have enough caster. Jeep won't do anything as everything is within specs and they can't find anything loose or wrong with the front end.
My caster is 4.1 degrees. Please post up your caster, lifted or not, if you have the figures. Also if you're jeeps wanders at highway speed or not
Thanks for your help
Old Aug 25, 2013 | 04:52 PM
k0260's Avatar
I'm right @ +4* caster with just under 4" of lift. I get a little wandering at highway speeds, not too bad though.
Old Aug 25, 2013 | 06:51 PM
Bryantch's Avatar
5 degrees per metalcloak recommendations, drives straight no wandering. 2.5 lift (actually sitting3.75 higher)
Old Aug 26, 2013 | 03:04 AM
2BAJeep's Avatar
How do you check your caster?
Old Aug 26, 2013 | 03:16 AM
BrowniesJK's Avatar
Mine is at +4 w/ 3.5" of lift. She is wondering more than I like so going to bump up to +5 next week.
Old Aug 26, 2013 | 04:56 AM
If you've had your truck aligned lately the alignment shop should furnish you with a readout showing before and after.
Old Aug 26, 2013 | 05:35 AM
2BAJeep's Avatar
Thanks TJ. Will be following this thread, as I learn more each day with this jeep!
Old Aug 26, 2013 | 06:33 AM
r3cluse's Avatar
I just finished a long arm install but didn't measure my caster. It's a little flighty at 70-75mph but fine at 65. I'll measure it tonight when I get home from work and post.
Old Aug 26, 2013 | 11:02 AM
SabrToothSqrl's Avatar
Default Don't Know
Mine came to me with a 3" BDS lift and 35s... drives as near to perfect as I think a jeep can / should. drives strait and well. Even up to 80!
