Wheel speed sensor?
Old Apr 6, 2013 | 03:40 AM
wranglerbrotherhood's Avatar
Default Wheel speed sensor?
So I've been having issues with my wheel speed sensor on the driver side front wheel for a few days now. And last night as I was driving the wheel started making this really weird noise, like something was binding up and dragging. I stopped to check it out and when I found nothing visibly wrong I went to start driving again and it moved about 4 feet and the front driver wheel completely locked up and I couldn't go forward. Sound like a wheel speed sensor issue?
Old Apr 6, 2013 | 03:52 AM
MikeLisa's Avatar
My brother-in-law just had Same issue. His brakes had locked up.
Old Apr 6, 2013 | 03:53 AM
TheDirtman's Avatar
I belive the traction control works off the rear brakes not the front. Doubt it would be a sensor. If the sensor is bad you will have lights on the dash as well.
Check for loose bolts on the caliper. I have seen people loose them when they were not properly torqued.
Old Apr 6, 2013 | 04:20 AM
Well the abs light, trac control light and ESP light have all been on for a few weeks and when I first start the jeep and drive it, the front brake locks up just a little for the first like 2 minutes of driving when accelerating. I looked around on the forum and a lot of guys said wheel speed sensor, I think it just finally went all the way and won't unlock now
Old Apr 6, 2013 | 05:18 AM
TheDirtman's Avatar
Swap them from side to side and see if the brake that locks up changes too.
Old Apr 6, 2013 | 05:54 AM
Just double checked in the daylight, one of the caliper bracket bolts is missing and the caliper lodged itself inside the rim. Gouged a nice metal stripe around the inside
Old Apr 6, 2013 | 05:55 AM
TheDirtman's Avatar
So, is that a thank you for the help?
Old Apr 6, 2013 | 07:24 AM
Just had to go through the setup again and make sure there wasn't anything else messed up that I'd need to ask about haha. I appreciate it man thank you
Old Apr 6, 2013 | 07:57 AM
TheDirtman's Avatar
Hope it is an easy fix.
Old Apr 6, 2013 | 04:34 PM
The gouge that the caliper put in the rim ended up causing a pinhole leak in the rim. Had to get my 35 mounted on the spare rim and get new bolts for the caliper but it's all back together and driving alright now
