Originally Posted by speed2005
(Post 2363812)
I didn't post the question as I was thinking it. Why is this available on the JK when no other cars offer such an option? The 3.8 is not a.diesel
If you buy 99% of vehicles off the lot, they already have the blockheater installed. It is an option though, as others have stated, in the South vehicles do not require a block heater. I bought a used Toyota in the 80's, and found out that there was no block heater. It did not take long to install one, as temps can dip pretty low here. |
Originally Posted by ronjenx
(Post 2363844)
Mine starts just fine in -30°F without a block heater.
It's nice to have, but not necessary. My VW TDI even starts with no block heater when it's that cold. |
(Post 2363844)
It's nice to have, but not necessary. My VW TDI even starts with no block heater when it's that cold. I'm sure the Jeep will start with it that cold out - my Cherokee did, but you have to worry about engine wear. Even more important, by plugging it in you get a jump start on getting some heat in the Jeep! Thanks to all who replied, I'll check by the battery and fuse box for the cord. |
Originally Posted by RichN
(Post 2364359)
Not to flame you, but you must have one magic TDI. My 1998 Jetta I had might start at 5 below (if the sun was out) but that's it. My Dodge CTD has started at minus 18 but it took a couple of tries and it was a grumpy SOB smoking out the whole neighborhood.
I'm sure the Jeep will start with it that cold out - my Cherokee did, but you have to worry about engine wear. Even more important, by plugging it in you get a jump start on getting some heat in the Jeep! Thanks to all who replied, I'll check by the battery and fuse box for the cord. As for my TDI, it's not magic. It just does what it was designed to do. It has never failed to start, (with the exception of a bad glow plug wire harness) no matter how cold. I did install a heater on it, and I use it when I can. |
If your jeep does not have a factory block heater installed and you want to save a couple bucks buy a magnetic one there around $20 and work well .
| All times are GMT -8. The time now is 12:40 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
