Where's the ECU / ECM ???
Old May 20, 2007 | 09:00 PM
JonGiovani's Avatar
Originally Posted by CARGUYS
FYI: the ECM in most 06-current chrysler products is the dash cluster assembly. Be very carefull as this systemis now operating on CAN BUS which means in simpler terms that all signals in and out of the module are data; ie 1"s and 0's like your home pc. Throw out your test light and gat a data probe as its not just - and + anymore. Signals are sent as ohm values and improper probing can result in catastophic results. We can all thank MB for the R & D on this system. Be very carefull, the ECM worth a few thousand $$$$
The cluster is a seperate module, it is NOT the ECM! the cluster module is most commonly referd to as the BCM, or body control module.
Old May 22, 2007 | 11:49 AM
hdkiwi's Avatar
Originally Posted by jameswharton
You are wanting to install your Jet chip under the hood on the drivers side towards the front. You will see the computer module with 3 wire bundles (4 if an automatic) coming out the back (towards the rear) I beleive it is the terminal with white paint on it that you want to take off and install your chip in the the ECU and then the wire bundle in the back of your chip. I can't remember the exact plug for sure, just follow your instructions.
Has anyone noticed that during the winter this was the first area of the hood to have snow melted on it. Why would one put a computer in the hottest area of the engine? Stall bug anyone?
