who has the most miles on their JK??
#182
157,000k on my 2011. We use it off road ALOT. Only major issue was I got one of the torque converters that were under recall. other than that good to go!
#183
2010 sahara bought last march with 13,000 miles on the clock!
a year later, it has a little less than 30,000! no problems other than a wheel speed sensor and my window not rolling up(power window)
#185
2008 4door with 65k lets see the list of issues here we go passenger front axle seal and axle half replaced three times twice by a dealer that couldn't seem to put the seal in without damage, leaking transmission cooling lines bad roll over valve in gas tank twice loss of front shock bushings at 500 miles two weeks after purchase and now in the shop for motor noise the good thing is nothing out of pocket so far everything has been under warranty
#186
2008 JK- 78,000
Rear Axle seals- Both sides
Gas Tank Spits Gas at You-Recall
Transmission Lines-Recall
Gearshift selector cable fell of the transmission? Towed to stealership for the evening.
The first vehicle I have ever owned that i enjoy driving everytime i get in it......I would buy another one tomorrow if i had to.
#187
2007- Unlimited Sahara - 125,000 miles
I've only had this rig for about 5,000 miles, had to do a heater core within the first two weeks. Cylinder 1 misfire since December, just found out coolant is leaking into cyl. #1 so either head gasket, head or block. We'll find out soon. Still runs great after burning out all the coolant, 18 mpg (hand calculated). Hopefully this will be the last major cost for awhile.
