who has the most miles on their JK??
#41
about 66,000 miles...
sway bar assembly (short links with lift = inverted swaybar ) luckily warranty covered it
front pinion seal (warranty)
squeaky back seat (warranty)
cracked exhaust manifold (warranty)
2 windshields
I think the other side manifold is cracked now, but no longer under warranty...
2 windshields
#43
2007, Unlimited X. 39,000 miles.
Steering box leak (replaced)
Rear diff leak
Gas splash (replaced tank)
Hard top. Still leaks (paper towel on dash)
Slight wind noise with soft top (turn up radio louder or put top down)
Replaced passenger mirror (Tree took off, my bad)
Rear diff leak
#44
well I got 50000 kilometers on my JK and today is the last day for the 3yr/60000 bumper to bumper warranty. My clutch felt a little off late Satuday afternoon just as all the Jeep service departments were closing. Parked it after I got home with very little clutch pedal left, Well fast forward to today took it in to dealer at 7am this morning and they say the slave cylinder is gone. Yes its covered unbelievable..... I just worried about how soon it will go again. I had the same problem with my 92 YJ. Other problems with my 07 Rubi. In March of 09 I had almost no oil in my engine, started making a ticking noise, thought it was lifters, turned out to be a spun bearing. The rebuilt the lower end and all is well. Also had Radio issues, it would cut out when I rolled the window up. They reprogramed the cpu. Also had a problem with my traction control when I first bought it in Dec of 06. Also was putting on my to front freedom top pannels by themselves like it shows on their cofigurations on how you can, had the tunes cranked, was tightening them down and went a little to far and scred right through the fiberglass, my bad but its a design flaw and Jepp got me two new pannels.... All in all its still the best vehicle I have ever had, love the heat it throws out too!
#45
33000 miles
factory battery died at 2 years replaced under warranty
new airbag sensor
replaced main window switch under warranty
all hinges and doors have been repainted due to rusting- under warranty
real brakes have been replaced not under warranty
knock on wood nothing major but getting nervous...
new airbag sensor
#49
Dad's 2007 rubicon unlimited has 70,000 miles and ZERO problems. Just oil changes and we JUST got a new set of BFG AT tires. (yes, it took 68,000 miles to wear out the MT tires lol).
