Will changing shocks or u joints effect alignment?
Originally Posted by 08yellowx
Just to clarify, On some vehicles, changing the shocks or struts does require an alignment. But not on your JK.
Was just curious, why all the steering mods , LCA's, trackbars,tierods and steering box? you hard on things or what.
Still to this day though it doesn't drive just right and steering parts wear fast. Especially the steering boxes. I am thinking my shock and spring combo is off which is why it's so harsh and passing all the shock to the steering.
you might try dropping your tire pressure to around 25-28psi. I assume you have stock coils. If the ride feels harsh then try that first, then maybe shocks. the tire pressure can make a big difference, you dont need the max psi stated on the sidewall in them. It gets kinda tough when you start piecing things together instead of going with a complete suspension kit.(past experience)
That 3/4 space up front may have off-shot your alignment a tad...my BL on my TJ did the same thing...granted we are talking about a different vehicle but maybe the physics are the same...when you take the spacers out, update this thread to see if that does the trick...most likely you aren't the only one with that issue...
Good luck!
Good luck!
