Window scrape
Old Jul 25, 2009 | 05:34 AM
grnjkrubi's Avatar
Default Window scrape
Front drivers side power window has been making grinding noise when going up and down. Noticed the glass is getting a vertical line/scrape from rubbing
something inside the door panel.
Anyone else had this happen?
Old Jul 25, 2009 | 03:32 PM
flounder's Avatar
Hopefully its something the factory will fix and if they will make sure they replace your window too. I hate scratched widows they just irritate u.
Old Jul 25, 2009 | 06:23 PM
grnjkrubi's Avatar
I have to take it to get the the soft top header replaced due to a whistling noise. Guess I will add this to the list. I noticed today it is on the inside of the window.
Old Jul 26, 2009 | 08:02 AM
RevyJKU08's Avatar
With the window...are you sure it may be a rock or dirt that slipped in along the rubber molding in the window? I noticed that after wheeling and was creating a scratch on my window. I just cleaned up the window seals and it seemed to help.
Sorry to highjack....but is there a soft top header TSB...I noticed our soft top has a big bend and wind noise is brutal now?
Old Jul 26, 2009 | 03:49 PM
grnjkrubi's Avatar
It sounds like the sound is coming from the middle part of the door and since the scratch is on the inside of the window I am thinking it is rubbing against an internal component. Maybe???
Don't know about a TSB but I was having an axle seal replaced and told them about the header noise so they ordered a new one. Took about 2 months for it to come in.
Old Jul 26, 2009 | 03:55 PM
Chris333's Avatar
i have a scratch on my window too but i dont have power windows. i figured it was a rock or something stuck in there
Old Jul 27, 2009 | 07:02 AM
RevyJKU08's Avatar
Originally Posted by Jared89
I noticed the same thing i was thinking it is not always this loud........is it, because i always try to ride with out the doors or top when i can.
The first year the softop was quiet...but I just noticed this spring the wind noise was brutal. Then I noticed that the front header was bent up from the windshield frame and was not sitting flush. I am not sure how that header would get bent???
Old Jul 27, 2009 | 07:14 AM
Heyspike's Avatar
Mine is bent too. I also had it replaced. Still bent. Waiting for the metal header if they ever make it.
