Wiring harness issue
Just purchased a 2007 X with power windows and power locks. Went to remove the doors for the first time last night to find that the previous owner had CUT the OEM wiring harness out on the drivers side for some unknown reason. It appears that they also ran extra wires into the door as well. Can anyone tell me where I might be able to find a replacement harness?!? I will need both the male and female connectors.
Thanks,
Okieveg
Thanks,
Okieveg
Is it the same number of wires on both sides? If so, just get new connectors. You don't need a new harness, just a quick disconnect at the door. Most audio and electronics stores carry them. Does not have to be the same connectors on both doors either. If everything works, just cut the wires, and put them at the right point in the connectors and you should be set. Should cost you <$10.
