wobble over bumps ?
Old Apr 23, 2009 | 06:19 AM
glivigni's Avatar
Question wobble over bumps ?
I have been noticing my 4 door X has been wobbling when I go over bumps in te road rather then the normal Up Down ? There are a few spots on a certain highway where I hit a slight bump on a slight turn and my jeep has a fast Left to right wobble that last for like 2 seconds after I hit the damn bump ! I have no lift and I have stock wheels etc. Is this common Bring on the wise cracks if I deserve them
Old Apr 23, 2009 | 06:48 AM
hohokom's Avatar
I guess I will be the first to say " Darn, it's a Jeep thing".
Old Apr 23, 2009 | 07:23 AM
boggle's Avatar
I would check out your steering stabilizer ? I had the same issue and mentioned it to my dealer, they checked it and found that the stabilizer was leaking fluid. Was replaced under warranty though. My rig was only 4 months old when it did this and I live on a rough dirt road so that might have contributed to it's early failure.
Old Apr 23, 2009 | 09:04 AM
Buster's Avatar
could be the rear track bar is loose. That can give you some side to side motion.
Old Apr 23, 2009 | 11:04 AM
Lorrel's Avatar
Yea, anytime you get side to side motion, check the track bars for tightness.
Old Apr 23, 2009 | 11:06 AM
While you are under there, check your tie rod and drag link for play side to side.
Also your wheel bearings (lift a wheel slightly off the ground and see if you get any play up and down lifting it).
Old Apr 23, 2009 | 11:08 AM
JulianK's Avatar
Definitely not normal! If it's under warranty, take it in and let them fix it. Otherwise, get underneath and see if everything's tight.
Old Apr 23, 2009 | 01:16 PM
glivigni's Avatar
thanks for the reply's . Its only 5 months old and under warranty. I will bring it in next week as the weather is gonna be in the 80's the next 3 days and the dealership isfor rainy cold days ! LoL
Old Apr 23, 2009 | 01:58 PM
Hellbound13's Avatar
welcome to the club is right.
Old Apr 23, 2009 | 04:44 PM
Chris333's Avatar
mine was doin the same thing and was leaking too. dealer replaced the steering stabilizer and its been fine since.
