WOL's Torque Values Writeup..
Ok Im confused. In WOL's write up on torque settings it says drag link to knuckle and drag link to knuckle (right side) is 55 pds. This is in the front suspension section.
Then in the steering linkage section it says drag link ball stud to pitman arm is 77 pds and drag link ball stud to knuckle is 63 ft pds.
So why the difference? are they talking about two diff things?
Are you asking why the numerical difference or why the difference in the measurement abbreviations? The measurement abbreviations are incorrect, anyway. The correct measurement for torque is "pound feet", not "foot pounds", and is abbreviated LB FT, or IN LB for "inch pounds", and lastly Nm for the metric "Newton meters". If you're talking about the different numeric values, I have no answer. Are the two fastners the same size? If not, that could account for the difference.
What I am asking is why the difference in specs. Its sound like those are two different names for the same thing (drag link ends).
So I am wondering which spec is right?
I THINK one was supposed to be "drag link" and the other was supposed to be "tie rod", but I'm not sure. There aren't two drag links, so that's my best guess.
Then the other one says the knuckle is 63 and pitman arm is 77. (the second description)
So that is what is confusing..
JK-Forum Founder
regarding your question, you should work with the higher values stated. 77 ft. lbs. where the drag link connects to the pitman arm and 63 ft. lbs. where it connects to the knuckle. you are working with tapered studs and so anything within this general range will do the job.
