Would a rubi disconnect fit without modification on a sahara?
Old Oct 7, 2012 | 06:57 PM
antonioso's Avatar
Default Would a rubi disconnect fit without modification on a sahara?
Hey guys, found a good deal on a rubicon sway bar disconnect with the motor housing and everything with an evo Manuel disconnect installed. It's from an 2010 jk, would it fit my 2011 Sahara without too much modification?
Thanks!
Old Oct 7, 2012 | 08:40 PM
4W-Jive's Avatar
Fwiw mopar sells the stock e disco unit as an accessory so probably
Old Oct 8, 2012 | 03:03 AM
ronjenx's Avatar
Yes. It will fit.
Old Oct 8, 2012 | 05:16 AM
jaker t5's Avatar
Thanks!
My question is why you can get a set of quick disconnect for a 150 and they will always work or you buy that and it sometimes works or just breaks
Do some home work on it first and hear what people are saying
Old Oct 8, 2012 | 05:51 AM
ronjenx's Avatar
There are times when having the sway bar links completely disconnected is best.
If the OP isn't into extreme flexing, he'll be fine with the unit he is looking at.
The one he is looking at has the EVO Disconnect installed, so all the high-failure-rate parts are removed.
Old Oct 8, 2012 | 12:24 PM
powerplant69's Avatar
Don't do it, my Rubi swaybar has play in it at the connection and is really annoying.
Old Oct 8, 2012 | 12:27 PM
antonioso's Avatar
for 175$ i got the fairly brand new rubicon sway bar with the EVO manuel disconnect and the working motor if for what evry reason i decided to wire everything up. It was less hassel then buying disconnect and wheel spaces and most disconnects require.
