Wrangler 2008 transmission radiator
Hello
What´s the good brand of automatic transmission radiator? thanks |
Originally Posted by jeepspecial
(Post 4345000)
Hello
I put the mopar one on mine just so I didn't have to fabricate anything myself and to keep my warranty in place. Kinda plug and play install but slightly on the expensive side. My is an 08 also. You need to have a trans cooler for sure that's why they added it as standard in the later years.
In their infinite wisdom, as they did (unsuccessfully) on the old LJ/TJ, on the first gen JK automatics Chrysler put the transmission cooler at the bottom of the A/C condenser. Insufficient airflow combined with marginal capacity. Adding an auxiliary trans cooler is almost a must on these JK automatics. Any good parts store cooler kit will do the job, but the Mopar "towing accessory" cooler mounts like factory and is probably best all around long term. Jeep suggests an operating temp of 180 degrees for the 43RLE trans in the early JKs. With the Mopar cooler mine rarely exceeds 170.
