Archived - Jeep XJ Cherokee & Grand Cherokees Discuss the Jeep XJ Cherokee and Grand Cherokee at our sister community. This includes all Jeep XJ's made between 1984-2001 and all Grand Cherokees made to this date.
90 cherokee wont start
Old 11-20-2012, 11:34 AM
althy's Avatar
Default 90 cherokee wont start
I've replaced my starter and starter relay, all I'm getting is a click when I turn the key. Any suggestions on what to do next?
althy is offline
Old 11-20-2012, 11:50 AM
WIRubi's Avatar
This may be an obvious answer but you checked the battery right?
WIRubi is offline
Old 11-20-2012, 12:08 PM
ronjenx's Avatar
After checking the battery, as mentioned....
Check the battery ground cable, and engine ground cable, for looseness, corrosion, and corrosion in the crimp where the wire goes into the connection lugs.
Check the battery Positive cable that goes from the battery to the starter, for the same conditions mentioned for the ground cable.
ronjenx is offline
Old 11-20-2012, 01:33 PM
althy's Avatar
Checked the battery cables after putting in a higher output battery. None are corroded or brittle. Just replaced the flywheel position sensor and still nothing.
althy is offline
Old 11-20-2012, 01:56 PM
ronjenx's Avatar
You checked the battery cables, but how about the engine ground cable?
Does your negative battery cable go directly to the engine? There should also be a ground strap between the engine and the body.
Is the click you hear, coming from the solenoid on the starter?
If so, make sure there is 12 volts present at the large positive wire on the starter, at the bolt on the starter.
ronjenx is offline
Old 11-20-2012, 02:33 PM
althy's Avatar
Ground cable is good.. can't quite tell where the click is coming from
Also, is there an obd port?
althy is offline
Old 11-20-2012, 03:37 PM
Sponsoring Vendor
chris@offroadevolution's Avatar
it could be a bad computer. I had a similar issue. A new computer solved it.
chris@offroadevolution is offline
Old 11-20-2012, 03:39 PM
Mach2Plus's Avatar
Try starting in neutral. Could be your neutral safety switch.
Mach2Plus is offline
Old 11-20-2012, 03:48 PM
JKingAround's Avatar
I've had battery cables that looked good until I cut them open and were corroded inside.
JKingAround is offline
Old 11-20-2012, 04:32 PM
althy's Avatar
Replaced the computer less than a year ago.
I can hear the neural safety switch click, and I've tried starting in neutral. I wish it were a manual so I could try a push start. I'll have to try cutting the cables open to see if they're bad inside.
althy is offline
Quick Reply: 90 cherokee wont start
