Pillar antenna mount & Under-dash HAM radio setup
Old 12-09-2016, 06:44 PM
javara's Avatar
Default Pillar antenna mount & Under-dash HAM radio setup
Bought a pair of rugged ridge's pillar lights mounting,
But only use 1 for light, so I use the other one for antenna
Gotta make the hole a little bit bigger for the antenna socket, though..
ID:	662509Click image for larger version
As for the ham, I use dual-band Yaesu FT 8900r with detachable face.
I put the face under the hazard button using velcro stip, and the radio under passenger's seat. (mine is RHD)
ID:	662508Click image for larger version
ID:	662511Click image for larger version
*sorry for bad pictures
Old 12-10-2016, 05:41 PM
bbolander's Avatar
I put mine under the passenger seat too. But I used the mounting bracket and fastened it to an existing metal plate using medium office binder clips with the cable connections facing outward. Doesn't bounce around that way.
Old 07-27-2017, 03:26 PM
Maniak907's Avatar
Default Antenna
What antenna are you using on your pillar mount?
Old 07-29-2017, 05:14 PM
LBJ
LBJ's Avatar
I used the NM0 antenna on mine and it works really well. I got the brackets from Amazon, made the hole a little larger and haven't had any issues. I believe my antenna is about 34" long.
Old 07-31-2017, 12:42 PM
Maniak907's Avatar
Okay, I'm getting my order ready. Im going with the UV-50X2 50 Watt Dual band radio with the Rugged Radio A-Pillar Mount. Just trying to find a decent antenna. Thinking of using the Larsen NMO220C
Old 07-31-2017, 05:25 PM
coolhand129's Avatar
Larsen and comet make very good antennas. You will be pleased.
Old 08-10-2017, 02:04 PM
duluthjk's Avatar
I thought about mounting mine under the seats but when I looked under there and saw how much dirt and mud were there from running doorless I chose the glove box.
How does having the antenna that close to the window affect transmission and reception?
Old 08-11-2017, 02:59 PM
bbolander's Avatar
The OP can respond, but we did an antenna study at a group picnic years ago. I had an LJ with a tuffy security box in the back and a ham and cb mag mount antenna on the metal box about 1 ft away from the roll bar. SWR was terrible. When I moved the antennas further away from the roll bar the SWR was fine.
Quick Reply: Pillar antenna mount & Under-dash HAM radio setup
