Rugged Ridge Switch Wiring Diagram
#21
Rocker Switch Wiring
I don't dabble with wiring that much and recently got the Rugged Ridge Switch and was looking for instructions on wiring it. Found a great video that explains how to hook up the power to it properly.
Hope this helps
http://www.youtube.com/watch?v=6ndOlIgn1ys
Hope this helps
#22
Hope this helps
Hope this helps
And welcome to the forum, jimps.
#23
Not sure how safe this is but it helps with wiring management through the firewall
The positive and negative wires coming from the pillar I am going to bundle like this. Not sure if I need to change the gauge of the rat tail but I used 16 gauge all the way. I uploaded the picture without the finishing electrical tape or heat shrink I will use over the copper crimper.
#24
You have 4 switches in the pillar? Usually you just run one wire to the first switch and then jump the first to second, second to third, and third to fourth. Same with the ground. But that should work too. The control circuits do run on milliamps so 16 gauge should be fine. It's a good idea to put a 3A fuse on the control circuit as well.
#25
I bought a bussman fuse/relay box from ebay with that 3 amp fuse that leads to this switch pod. The guy who made it said he has instructions so I feel confident putting this in.
To be honest, this is actually fun. My niece also has a 2015 jk 2door and what ever mods I do that she wants, I will do on hers. The experience I gain from mine will benefit her for sure. Haha!
#26
Thanks 14Sport. I didn't even think of daisy chaining it that way. I'll look for connectors that will let me do that. The less rats nest the better.
You should practice on your neice's Jeep so yours will be perfect.
Edit: I know I have a couple of pics posted where it shows daisy chaining some relays. I'll see if I can find them for you.
#27
Found it. You can see where I daisy chained four relays together in this bench test in post #6.
https://www.jk-forum.com/forums/jk-e...1/#post4056557
#28
#29
Haha...glad I could help. It seems there is always something for us Jeepers to be spending money on though.
#30
This might help you as well. It is the basic wiring schematic for wiring your own 4 switch box.
You don't have to return the accessory grounds back to the box. You can just ground them to the chassis to save wire.
