JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
too much flex?
Old 10-14-2009, 07:15 AM
stevedolce's Avatar
Default too much flex?
ok..feel free to laugh but is it possible to over flex and dislodge a spring?
like i said...feel free to laugh
thanks
steve
Old 10-14-2009, 07:18 AM
jkkat's Avatar
yes it is possible, i have seen it with JK's that eather had no shock in a corner or too long of a shock.
Old 10-14-2009, 07:30 AM
JPTwinz's Avatar
Too long of a shock can allow the spring to flex too far though usually you'll hear (or see) your ABS or brake lines snap before that happens. The front spring has a bumpstop top and bottom inside the spring which would actually help keep the spring in postion insted of flying out if you were to flex far enough so that the spring is loose. The rear spring also usually has a retaining clip at the bottom which keeps the spring in position though the spring could 'walk' a bit under full flex.
Old 10-14-2009, 07:52 AM
robin's Avatar
yes it is.......
Old 10-14-2009, 03:01 PM
Kahuna Mas's Avatar
This happened to one of the TJs on our trip this past weekend. Flexed to much, front spring popped out.
It sounded like a shotgun went off.
Old 10-15-2009, 06:40 AM
UnlmtdJKRubi's Avatar
Been there done that, ripped the brake lines off.
Old 10-15-2009, 06:58 AM
Slippery's Avatar
East fix guys. Make sure your springs have retainers installed at the bottom, front and rear.
Old 10-15-2009, 09:55 AM
So_Cal_Tay_12's Avatar
Looks like I need to look into this. . .
Old 10-15-2009, 12:48 PM
Littlejon's Avatar
On the Rubicon with the e-locker you can flip the swaybar discos and bend themif you overextend the front.
Old 10-15-2009, 01:18 PM
RescueX's Avatar
Wow! It looks like it had a retainer disk on the bottom too.
Quick Reply: too much flex?
