JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
too much flex?
Old 10-15-2009, 04:54 PM
backroadman81's Avatar
Happens alot on tj's and jk's that neglect to install proper bump stops and retainers
Old 10-26-2009, 09:34 PM
spinlock's Avatar
Originally Posted by stevedolce
ok..feel free to laugh but is it possible to over flex and dislodge a spring?
like i said...feel free to laugh
thanks
steve
It's funny now, but it wasn't when a spring lost its seat and took out the brake line on a friend's TJ when he had to flex his suspension on a lonely pile of rocks 50 miles from civilization. It took me 4 hours to tow him back to civilization in 110 deg heat.
Old 10-28-2009, 05:07 AM
greenmachine07's Avatar
if you have that much flex you should not use your shocks to act as limiting straps....that is what limiting straps are for
Old 10-28-2009, 05:31 AM
GoodysGotaCuda's Avatar
And don't check things. i still have stock stops and retainers, however I have fully flexed mine to inspect lines/spring/ wiring, etc. Be a bad time to lose a brake line! (like any isnt a bad time!)
Old 10-29-2009, 07:26 PM
w squared's Avatar
You can definitely lose a spring at full droop with a modified setup. Spring retainers are your friend...or limiting straps once you start getting into really big travel.
Old 10-30-2009, 12:53 AM
Limiting straps will not only help keep you from loosing a spring and tearing a break line/ abs wire but it will also save your shocks from being over extended and break or leak.
Quick Reply: too much flex?
