#5121
A true comparison should be done with similar cars, similar interior colors & materials, and quite a few more variables in control. Most tests aren't meticulous enough.
#5124
Did the Whipsaw trail and French mines detour in British Columbia, Canada this weekend. The trail was wet from a heavy rain storm the night before which made some of the obstacles challenging. I think a stock jeep would need to winch its way up on one or two of the sections pic from the trail around 6000ft. group stopped at a lake. Then we went to the French mines, here was a cool view from near the mines playing around on a stump at the overlook, had to do a poser shot. walked around inside the mine, cool things to see leaving the mine view just outside the mine
#5125
#5126
Well there ya go! You're one of those suspicious fellows!
Sorry your holster was broken. Yeah, I got quite the search once when they were suspicious that I might have had a handgun hidden somewhere. Didn't, but I tell you, I was sweating it, wondering if I had a stray magazine or handgun ammo or something else somewhere in the rig, forgotten by me...
Fortunately I didn't. All the other border crossings into Canada, with my rifles, have been effortless.
Regards, CW
Regards, CW
#5127
I'm about to order terraflex c gussets? Anyone on here running Dana30 with gussets? Would you recommend sleeves for overland expeditions?
Thank you,
Eric
Thank you,
Eric
#5128
I'm running sleeves and gussets on a D30 (actually doesn't matter whether it's a 30 or 44 since the axle C's and tubes are essentially the same between the two). I think they provide peace of mind. Sometimes the higher speeds and harder impacts involved with traveling a bumpy/washboarded dirt road are harder on our running gear than rock crawling.
#5129
I have my housings sleeved and gusseted. I did synergy, but they are all the same. Mine had to be welded on, which requires removing housing paint and repainting after welding.
It is a good thing to do. Whether you're hardcore rock crawling or overlanding it is a wise upgrade to do to prevent having issues on the trail.
