37's on a D30?
37's on a D30?
I know this question comes up a lot, but would the D30 hold up with 5.13's, a 3.5 lift and 37's if I hold off on the wheeling for a bit and just keep her on pavement?
On the pavement you should be fine for awhile. There are people who wheel 37s on a 30 often. As long as you don't do anything stupid it should last awhile.
the higher u go in gear ratio the smaller the teeth get. a 30 already has a much smaller ring and pinion v. the d44. going as high as 5.13 which i think is max on a 30 is really pushing it....then throwing larger/heavier 37's on there will lead to a failure.
edit: go for it and let us know how it works out.
Theres a guy I know that runs 37" mud grapplers on his D30 that has gussets and ARB diff cover and its 5.13 geared. He drives 30K a year on pavement with at least a dozen off road trips a year. still going strong
