Comp cut and streching my 2009 2 door JK and installing the TNT Guardian front bumper
I have ordered all of my parts from Rock Krawler and River Raider for the comp cut. I will be posting up pics along the way of the build project. My plan is to stretch the JK a minimum of 8" with the Artec spring perch set I can get another inch with a total of 9" which will put the jeep at 105" wheel base. The rear body armor is coming off and will be for sale and my front bumper if anyone is interested. Let the fun begin!!!!!!!!!
okay I started pulling everything off the jeep today and began to cut the passenger side. I will be posting pictures step by step for the build. the cutting was really easy after I measured and taped out the rear fender, I spoke to river Raider and they gave me ruff measurements to start the cut, and they mentioned my fenders would be shipping by the end of the week. For the stretch I have used Rock Krawlers brackets for the 8 inch kit along with Artecs spring perches to get another inch back. I also will have my control arms next week which are being made out of 7075 aluminum, drilled and threaded for Currie joints. RH thread on the lowers and RH-LH on the upper to adjust pinion angle easy.
I also had to see how it looked with the tire in the wheel well......lol
Here are some current pictures of the most recent progress on the comp cut. I will be relocating the current fuel door to the front of the driver tire which looks like it will be pretty simple to install, I did cut off the rear track bar bracket and the bump stop mounts on the passenger side and cleaned the frame up, next will be cleaning up the passenger side.
Here are a few pictures of the coil spring relocation from Rock Krawler which makes this a complete bolt in by using a factory cross member which is perfect for the 8" stretch, I will be getting the other inch by using the Artech spring perch mounted on the axle which can be welded in for stock or a 1" stretch.
