Comp cut and streching my 2009 2 door JK and installing the TNT Guardian front bumper
Old 04-04-2014, 04:09 AM
Phatchick's Avatar
Default Comp cut and streching my 2009 2 door JK and installing the TNT Guardian front bumper
I have ordered all of my parts from Rock Krawler and River Raider for the comp cut. I will be posting up pics along the way of the build project. My plan is to stretch the JK a minimum of 8" with the Artec spring perch set I can get another inch with a total of 9" which will put the jeep at 105" wheel base. The rear body armor is coming off and will be for sale and my front bumper if anyone is interested. Let the fun begin!!!!!!!!!
ID:	543125Click image for larger version
ID:	543126Click image for larger version
ID:	543127Click image for larger version
ID:	543128Click image for larger version
Old 04-04-2014, 05:37 PM
Phatchick's Avatar
okay I started pulling everything off the jeep today and began to cut the passenger side. I will be posting pictures step by step for the build. the cutting was really easy after I measured and taped out the rear fender, I spoke to river Raider and they gave me ruff measurements to start the cut, and they mentioned my fenders would be shipping by the end of the week. For the stretch I have used Rock Krawlers brackets for the 8 inch kit along with Artecs spring perches to get another inch back. I also will have my control arms next week which are being made out of 7075 aluminum, drilled and threaded for Currie joints. RH thread on the lowers and RH-LH on the upper to adjust pinion angle easy.
I also had to see how it looked with the tire in the wheel well......lol
ID:	543295Click image for larger version
ID:	543296Click image for larger version
ID:	543297Click image for larger version
ID:	543298Click image for larger version
Old 04-04-2014, 07:12 PM
Flexer07's Avatar
Subscribed. My plans when funds are available lol
Old 04-05-2014, 03:06 AM
Phatchick's Avatar
I will keep posting pictures up as I go along
Old 04-06-2014, 01:40 PM
Phatchick's Avatar
Here are some current pictures of the most recent progress on the comp cut. I will be relocating the current fuel door to the front of the driver tire which looks like it will be pretty simple to install, I did cut off the rear track bar bracket and the bump stop mounts on the passenger side and cleaned the frame up, next will be cleaning up the passenger side.
ID:	543690Click image for larger version
ID:	543691Click image for larger version
ID:	543698Click image for larger version
ID:	543701Click image for larger version
Old 04-06-2014, 01:51 PM
Phatchick's Avatar
Here are a few pictures of the coil spring relocation from Rock Krawler which makes this a complete bolt in by using a factory cross member which is perfect for the 8" stretch, I will be getting the other inch by using the Artech spring perch mounted on the axle which can be welded in for stock or a 1" stretch.
ID:	543708Click image for larger version
ID:	543709Click image for larger version
ID:	543710Click image for larger version
Old 04-07-2014, 02:55 PM
Phatchick's Avatar
I received the TNT Guardian front bumper today and started the install while I am waiting on my other parts to arrive.
ID:	543993Click image for larger version
ID:	543994Click image for larger version
ID:	543995Click image for larger version
Old 04-07-2014, 02:58 PM
Phatchick's Avatar
You have to remove your front bumper and sway bar first.
Then you have to remove the crossmember and grind all the areas smooth. Plasma cutter will make short work on this step.
ID:	543998Click image for larger version
ID:	543999Click image for larger version
Old 04-07-2014, 03:03 PM
Phatchick's Avatar
You will then take the templates that come in the kit to mount using your factory sway bar bolts and holes to line everything up. Then mark and cut the frame and clean up all sharp edges with a grinder.
ID:	544001Click image for larger version
ID:	544002Click image for larger version
ID:	544003Click image for larger version
Old 04-07-2014, 03:07 PM
Phatchick's Avatar
Here is are some test fit pictures with the bumper on the jeep, this is the best approach angle front bumper on the market.
I will post up more info when I continue the installation.
ID:	544005Click image for larger version
ID:	544006Click image for larger version
ID:	544007Click image for larger version
Quick Reply: Comp cut and streching my 2009 2 door JK and installing the TNT Guardian front bumper
