ESP Kill Switch Writeup
#81
Here are my pics. you can see where I spliced inline with the purple wire. I used a solid blue wire and installed a butt connector. Works great for me and all of mmy wiring is tucked away nicely. Granted if you are worried about warranty stuff you obviously don't want to mount your switch where I did.
#82
Hey, so I did the write up and everything and all of a sudden the switch didn't seem to control anything and esp/bas/traction control were all off and lit up on the dash. I tried restarting the engine with the switch in different positions but still no luck. I eventually just reconnected the wires under the center console as they originally were, still didn't work. Today I just tried replacing every fuse somewhat related to the esp functions and that didn't work either. I have an OBD II scanner but it hasn't shown any problems. Any advice? Or should I just take it to the dealer? I'm off warranty so I don't have to worry about voiding anything
#85
Well I tried disconnecting the battery for a little while and nothing changed. I also can't see any place a connection was bad. I did get caught in the rain a while ago and it drenched the inside, would that have messed anything up? I tried the fuses but still nothing. Hopefully the Jeep's computer isn't messed up.
#86
#87
Right, yea it worked great for about two months then it started acting up.
#88
I have a 2013 Auto and wanted to do the Wheel Dance thing as that still keeps ABS but disables Traction Control. The reason i wanted to keep ABS is i wanted the Hill Decent Function to still work, and (correct me if im wrong) Hill Decent works off the ABS system so should still work?
But after trying many times i cant get the Wheel Dance to work which is unfortunate, the feature must be disabled on 2013 jk's ?
So i will now disable it altogether by cutting the purple wire. I will use a Momentary Switch (like the jeep panel esp switch is momentary) not an on/off switch, so that way the system will re-enable automatically as soon as i turn engine off/on.
#89
Well I have some good news and bad news. Good news is that the dealership found out what's wrong with my traction control. Bad news is that a wheel speed sensor and wheel bering is out so that costs me about $500. That hurts the wallet.
Guess the problem was never because of the ESP kill switch after all!
#90
