ESP Kill Switch Writeup
#161
Here are my pics. you can see where I spliced inline with the purple wire. I used a solid blue wire and installed a butt connector. Works great for me and all of mmy wiring is tucked away nicely. Granted if you are worried about warranty stuff you obviously don't want to mount your switch where I did.
#162
To be sure remove the two tourque bolts on the center consul at the rear seat and lift up, you will see the two purple wires you need to cut the one with the stripe. If you have a voltmeter connect it to the wire under the consul and make a little slice on the wire that you found under the dash and tone it out, if it is the same thats your wire!
Valj
Valj
BlackDiamond (03-23-2021)
#163
Cut the "alone" one, not the one in the twisted pair. (You assume all risk in this)
#164
I have a '12 and did this mod 2 days after the OP's write up. I absolutely love it. The increased mileage is awesome. I have to admit I miss using the cruise control. Has anyone figured out a work around yet?
