"Hybrid" Lift
"Hybrid" Lift
On my stock weight 2014 JKU, I've thought about using RK 1.5" springs with stock rubicon shocks and stock rear sway bar links in the front. Only doing light trails, etc. Would those springs and shocks be ok together? Thanks
RK lift measurements are with aftermarket bumpers / winch, etc. So you may see a little more lift than 1.5". That said, you will likely be ok with that setup but consider some shock extensions to be safe.
I'd rather get aftermarket shocks than run extensions, at that point I'd do a larger, more inclusive lift. Maybe I'm better off with the TeraFlex 1.5'' leveling coils. I really wanted the RK springs though
I already bought Rubicon shocks, looking for the tallest springs that work with them. Rather not use shock extensions. RK1.5'' or TF1.5'', any other suggestions? Synergy 2'' or JKS 2'' maybe?
Thanks so much
Thanks so much
