jeep build with a super 60/sterling setup
#21
Since the super 60 has 55 teeth in the front and the new sterling tone rings also have 55 teeth, I am hoping t can play with the Programer a bit to get my Speedo calibrated. Unfortunately I won't Know until after I install the axles and order my driveshaft.
#22
so, does anyone know how long my front brakelines will have to be with a 14 inch coil over? I figured on 4 inches up travel and 10 inches down travel, but its not enough info to validate the length I will need for my brake lines. Would appreciate somone with a coil over jumping in. Thanks
#24
agreed with dirt. i ran 24"s on my 12" travel shocks and it was way overkill...that seems about right.
Last edited by Maertz; 03-03-2014 at 03:59 PM. Reason: NVM realized your doing 3 link
#25
I appreciate the fact that your project is by far more complex than anything I would take on,,, but if I'm reading this right,, are you going to do all this work, and custom fabrication without any idea if the electronics connected to the tone rings will work, or be able to be made to work? That seems like a pretty big gamble! What ar your options if you cant make it work? I really hope it all comes together!
#26
#27
well, my current job has me surrounded by computer programmers, so naturally I picked their brain on this stuff. Here is what they told me...
Each wheel sends a signal in 1's and 0's. The ESP program doesnt really understand wheel spin but rather what is the acceptable variance between each wheel. should those parameters exceed certain thresh holds, then the program will execute a set of comands based on the type and rate those parameters are exceeded.
They guessed that the speed is based on an average of input it receives. The speed is based on a set of inputs that are applied to an algorithm that spits out your speed,.
So if what they say is true, then as long as each wheel has 55 teeth... then I should be good, .
Thanks guys for your quick response on the brake lines. I am thinking of going with Crowns.
#28
Assuming the computer is just looking for an individual tooth count from each wheel, traction control and ABS should be ok BUT speedo and odometer have a calculation to perform which uses the number of teeth they consider as a full rotation (stock is 52) and the tire diameter which you can change with a tuner and as I type this I stumped myself into trying to figure out how a 55 tooth ring would ever be truly accurate
#29
Not necessarily. First assuming what I heard is accurate, the tooth gap is what tells the computer to send a 1 or 0. If the gap is off, then things will get weird. Again this is an assumption***
#30
You are soooo raining on my parade! All kidding aside... if the gap is important, then I do have a problem and I am back to square one. If its based on number of teeth per rotation, I can manipulate other parameters like wheel size and gear ratio to get my speedo to match my gps. I know gap can be an issue as it relates to the sensor's ability to pick up the signal, but I don't know if the gap is factored into the equation around speed. I am hoping that ford has the same gap sensitivity issues as Jeep. That said, it is strange that each manufacture uses is different teeth count. Well, one way or another I will definitely let you know the outcome of this.
Look forward to your discovery
