Sponsored by:
Sponsored by:
Lift Kit
Old 01-14-2017, 11:24 AM
edgarg1223's Avatar
Default Lift Kit
Can I install a Teraflex 2.5 Lift kit and still run my factory wheels and tires till I am able to afford my aftermarket wheels and tires?
Old 01-14-2017, 11:29 AM
shawnphi1's Avatar
Yes. I did same thing for about 2 months til I got new wheels and tires.
Old 01-14-2017, 11:35 AM
catahoula's Avatar
Sure unless you run factory tires with larger wheels you might need wheel adapters.
Old 01-14-2017, 12:36 PM
TheDirtman's Avatar
You can by why would you?
Old 01-14-2017, 01:09 PM
sa29560's Avatar
I'd say tires and wheels first.
Lift isn't necessary unless your looking to go above 35s. It helps, but some trimming and you can run 35s no lift.
Old 01-14-2017, 01:14 PM
saint mucus's Avatar
Getting ready to do the same lift but don't want to get rid of my custom wheels, BS is 5.51" so I just added 1.5" hubcentric spacers. I'm going to run these spacers a month or so before the lift just to see if I can trust them, read so many second hand negative comments about spacers but only good 1st hand reviews if installed and maintained correctly. I like the look of the wider stance and the way the tires stick out just past the fenders now too.
Old 01-14-2017, 02:04 PM
edgarg1223's Avatar
Thanks
Old 01-14-2017, 02:05 PM
edgarg1223's Avatar
I cant afford everything at once, and with so little time I am trying to do a few things at a time
Old 01-17-2017, 03:30 AM
Potato Potato's Avatar
I installed this lift with stock wheels and tires (Sahara 18in). It was recommended that the rear sway bar links be mounted inwards to allow for additional clearance. I did mount my links inboard, however it didn't really appear to add clearance due to the mounting stud on the lower.
I guess just be aware of this and check before bolting everything up.
Old 01-17-2017, 09:43 AM
resharp001's Avatar
Received 1,825 Likes on 1,595 Posts
Have to admit, only wandered on this thread cuz I noticed Potato Potato had the most recent response. LOL, great name!
Quick Reply: Lift Kit
