Sponsored by:
Sponsored by:
Rear Axle shafts seized
Old 01-15-2017, 05:42 PM
creelclmsn's Avatar
Ok so I have tried heat, a slide hammer, a sledge, pry bars, 2 cans of PB blaster and I still can't get he rear axles to break loose in my jk... does anyone have any ideas?
Old 01-15-2017, 06:05 PM
ronjenx's Avatar
Everything is off the outer end? All four retainer plate nuts are off, and the retainer plate is loose?
Old 01-15-2017, 06:07 PM
creelclmsn's Avatar
Yeah the four flange bolts, the e brake spring and nothing will break loose... I have the diff cover off and when I look in I can see the splines move less than a 1/4 in when I pull and push. It has to be the bearing housing seized to the axle tube
Old 01-15-2017, 06:09 PM
ronjenx's Avatar
You didn't mention if the retainer plate is loose or not.
Old 01-15-2017, 06:10 PM
cidd's Avatar
Dynamite 😡??? What are you trying to do?? Pull the axel out of the housing? Did you remove the gears from the pumpkin? After that they should wiggle out . They might get hung up a little on the bearing but should pull free. You didn't seize the bearing to the axel did you??
Old 01-15-2017, 06:12 PM
creelclmsn's Avatar
The retainer plate has the four flange bolts they are loose... the bearings is seized yes.... you can't take out the gears with out removing the axle shafts first
Old 01-15-2017, 06:13 PM
ronjenx's Avatar
No need to do anything in the pumpkin to get the axle shafts out.
creelclmsn's Avatar
I'm installing a rear locker if I can ever get the axle shafts out
Old 01-15-2017, 06:18 PM
karls10jk's Avatar
My driver's side was stubborn. I put the rotor back on and proceeded to destroy it until the shaft came out. The passenger side slipped right out.
Since you've already been the slide hammer route, have you tried to bolt a tire/ wheel combo back on there to see if the added diameter will give you the leverage you need?
Old 01-15-2017, 06:20 PM
ronjenx's Avatar
I know the nuts are off. I'm trying to ask if the retainer plate is loose, or is it still as tight as it would be if the nuts were still on. Do you get any movement of the retainer plate?
Quick Reply: Rear Axle shafts seized
