Rigid srq backup lights and spod help!!!!!!
So today I recieved my rigid SRQ backup light set Rigid Industries LED Lighting | LED Lights, Offroad, Marine, Truck Looking over the wiring from rigid it looks like the wiring kit has a 40 amp inline fuse and a 60 amp relay. I know with the spod I cut off the relay and other wiring and run the wires straight from the lights to the SPOD. From what I understand the SPOD can only handle up to a 30 amp fuse and a 40 amp relay. Is it possible to run these two lights to 1 switch on the spod or is it going to be too much power and if so will i have to use two switches then. Anyone with advice or help please respond ASAP. Thanks again - Anthony
The spod will run them fine. Mine were hooked up that way but are now tied to back up lights. I got tired of flipping the switch every time I was in reverse. Sent using smoke signals
no idea why they sent a fuse that big. The d2's I got a year ago came with a 15 amp fuse. Still too big. Maybe they buy fuses thinking people are going to run a 50 and a bunch of smaller lights on the same fuse. Couldn't tell you their reasoning.
