Rotating the Rubicon E-Disco motor?
Old 02-13-2011, 06:04 PM
  #21
kimp5756's Avatar
Default Good timing...
Originally Posted by RedJK2
Today I rotated the e-disco on my Rubicon. This thread hasn't been updated in a while, so I thought I would add more pics to hopefully provide some additional value. Special thanks to dmhines for his great pics and write-up. I would have been a little lost without his help. Note that the listed parts are slightly different than those mentioned previously. I had to improvise based on what was available at the local hardware store.
Parts include:
(1) 10mm bolt, ~4" long and fully threaded
(1) Sleeve, ~1.5" long
(3) nuts
(1) small diameter washer
(2) large diameter washers
Attachment 126862
Pre-assembled (for illustration purposes only; must be disassembled before install):
Attachment 126863
As mentioned above, the 4 sway bar frame bolts must be removed before rotation (pics included in previous posts).
Rotated e-disco with disconnected wire:
Attachment 126864
Installed. Note that the new bolt assembly replaces an existing housing bolt:
Attachment 126865
With the e-disco rotated and reassembled, the wire connector mount rubs the plastic shroud below the radiator.
Attachment 126866
Thanks for the update and writeup RedJK...Perfect timing as I am ordering the Expedtion One rubi skid tomorrow and will need to do this. Do you foresee any problems with the wire connector rubbing the radiator shroud? Should that be trimmed?
Old 02-14-2011, 03:42 AM
  #22
RedJK2's Avatar
That's a good question. I'm not sure if it's an issue, and was hoping others who have done this mod would be able to discuss. If it is an issue, I'm not sure why the shroud could not be trimmed.
Old 02-14-2011, 03:58 AM
  #23
rinkishJK's Avatar
u will have to trim the shroud a lil bit to clear the plug. Well not fan shroud the other piece.
Old 02-14-2011, 04:04 AM
  #24
RedJK2's Avatar
Originally Posted by BLKRUBI
Rotated up under the Radiator shroud...............
Thanks! Looking back to the first page, I think that is what this pic is depicting as well.
Old 02-17-2011, 04:45 AM
  #25
RedJK2's Avatar
I installed a new bumper yesterday and decided to snap some pics of the rotated e-disco while the bumper was off.
Pre-cut:
Post-cut:
Old 09-07-2011, 08:31 PM
  #26
H315M4N's Avatar
Just did this tonight. It was much faster and easier than I thought it would be!
Old 09-08-2011, 06:19 AM
  #27
Tuto's Avatar
Quadratec has a "kit"
http://www.quadratec.com/products/16315_6040.htm
Instruction w/ Pictures
http://www.quadratec.com/Assets/Installation/142641.pdf
******* Suspension Front Sway Bar Motor Relocation Kit
For 07-12 Jeep® Wrangler Rubicon & Wrangler Unlimited Rubicon JK
Quadratec Part No: 16315.6040
Manufacturer Part No: 5410-03-08
$9.99
This NEW Kit from ******* Suspension includes the necessary hardware to properly relocate the anti-sway bar disconnect motor out of harms way on you Wrangler Rubicon JK. It provides increased ground clearance as the sway bar motor becomes tucked up under the frame rails. This will allow you to run a front bumper without the lower Skid Pan for more ground clearance and better approach angle.
Old 09-13-2011, 01:17 AM
  #28
RedJK2's Avatar
I think I paid a few dollars less at the hardware store, but $10 isn't too bad for a Jeep mod.
Old 02-10-2012, 10:03 AM
  #29
nickcoleman's Avatar
I just order the parts from Quadratech ... figured it was worth the extra couple of bucks just not have pay for the gas to drive to the store.
Installing a new bumper next week ... so, this should be a no-brainer mod while doing that.
Quick Reply: Rotating the Rubicon E-Disco motor?
