2014 JKUR Hard Start
Have a 2014 JKUR been great so far! Lately though it has been hard to start. It is an automatic.
Seems like it has been happening more since cold. When it happens it is when I first start it up for the day or when it has sat all day at work. Going into stores and coming out it is fine.
When it hard starts it will turn over a lot and then stumbles like it floods out, and then it will start.
Not really sure what could be wrong.... Only has 4000 miles! Any help or ideas would be great!
Prob a defective battery, yes sometimes they come out defective from the factory.
or just drained if it was sitting for a long time at the dealers lot before you bought it.
No worries friend good luck
I disconnected the battery and let it sit for approximately 10-15 minutes. Hooked it back up and tried to start again and it fired right up. Was at jeep event and had to move it and started good again. Went to leave and it took longer and sputtered again.
Came home and put a battery tender on it and see what happens in the morning.
Sounds to me like a IAC or ETB issue stumbling like flooded doesn't sound like a battery issue resetting the KAM may help clear the ETB fault temporarily, being it to the dealer hopefully you have a good one close against popular belief there not all bad
Unfortunately I don't have a good dealer close by. I would have to travel about 2.5 hours to get to one I would trust.
Let me see if I can figure it out.....
So far so good. Hasn't had anymore issues. Wonder if the warm weather has anything to do with it....it's been near 60 the last two days. Supposed to get cold again tomorrow. Keeping fingers crossed.
if it is getting improper fuel pressure.. (NOTE not no pressure) it will be much harder to start when its cold out, as the engine requires more fuel for colder starts...
if the coolant or intake air temp sensors are defective and say read that the Jeep is warmer than it really is, the same issue can occur...
and it may still run fine when started and run a little as more sensors are reading..
another issue is that your fuel lines could be bleeding off all of their pressure fro ma bad check valve when the jeep sits still.. go to start it and it begins to start from leftover fuel in the injector area.. then immediately stalls.. then starts fine..
none of the above issues are likely to set a code as the parameters are not out of range for that particular sensor...
-Christopher
-Christopher
My 14 had a similar problem. Found out there is a tsb on them build dates 02/03/14 through 7/18/14. Tsb number is 18-054-14. It replaced camshaft sensor. Mine has been great since the fix.
