JEEP Won't Start -- It Clicks -- Intermittent at first -- Now almost constant
Key fob? Can't be that. Even with the wrong key fob, the engine will start, then shut off in 2 seconds.
Plugs and wires? There is nothing about them that can prevent the engine from turning over.
Linkage or neutral safety switch? Not in the traditional sense. If it were out of adjustment, it wouldn't even click. Try starting it in gear; it won't click at all.
There is a good possibility it is related to the JK's version of the neutral safety switch, though.
Inside the transmission, there is an item called the range sensor. It has 4 contacts that ride on the range selector. They have various combinations of "on" and "off". It tells the computer which gear the selector is in, including Park and Neutral.
These contacts are awash in transmission fluid. It's likely the contacts make a connection that's not quite perfect, and when the current goes through them, the connection is broken. It will be a good connection long enough to let the computer route power to the relay, but when the connection fails, the computer shuts off the power, thinking the transmission is no longer in Park or Neutral.
Moving the selector lever re-establishes the range sensor connections, allowing the entire start sequence to happen.
(This is all theory. I haven't been able to prove it, as mine has never had the "click-no-start" condition.)
Here is a picture of the range sensor contact points.
I had same problem with my '07. It was a crank sensor that was going bad. I have the shittiest service department there is, but they fixed this problem first try.
I was convinced it was the range selector. Mine did it a lot! But only in the summer when it was hot, once fall hit and things cooled off I never had the problem. However, since replacing my engine a year ago I have not had the problem? That puzzles me and makes me think the grounding issue may be the cause. Either way, all I had to do was jiggle the shifter and it would start. I didn't have to shift it, just a slight push or pull on the auto shifter.
Sponsoring Vendor
Epic-Addictions Representative
Mine does this frequently. I wouldn't say it's a click, it's more like the engine turns for what's maybe a 1/4 crank then stops. Bumping the trans shifter and cranking again gets it started. 07 auto with about 60k miles.
I've discovered my auto JK does this usually when I've driven in Reverse and then parked w/o engaging forward drive before Park. So obviously it's an auto trans sensor issue. I've gotten in the habit of putting it in Drive and moving forward a bit before setting it to Park when backing into a parking space. Maybe 1 out of 100 times I get the click & pop the shifter forward a bit or put it in N to start.
Update
Even with the spare key it did not start up. Just the "click." So I did as instructed and shifted the jeep in neutral. It started right up...
I'm going to call the shop and tell them tomorrow. I hope that whatever the problem is it's covered under the drivetrain warranty. What's your .2 cents now, considering the JK will start in neutral (it's automatic)?
Thanks!
Thanks!
Thanks!
Thanks!
