Sponsored by:
Sponsored by: DashLynx
Need help. Stuck on side of the road
Old 05-29-2015, 05:14 PM
EHarris's Avatar
Default Need help. Stuck on side of the road
I was in park. Disengaged the E brake and then went to make a u turn. When I did it felt like the brakes were still locked.
On the dash I have ABS light and ESP lit up.
All 4 rotors are burning hot.
Old 05-29-2015, 05:19 PM
EHarris's Avatar
Superchips reads my trouble codes are the following....
1 of 3
U1418 implausible right wheel distance signal received.
C1032 right rear wheel speed sensor signal erratic performance
C1035 right rear wheel speed comparative performance.
Old 05-29-2015, 05:29 PM
Jersey_Devil's Avatar
Well if it was me, now that u have the codes, if I was stuck on side of the road I'd disconnect the battery for a few minutes to let the system reset and see if it goes away. Then once ur home and off the road look into it some more. Sorry I can't give u a definable answer for ur problem, but that's what I would do in ur situation.
Old 05-29-2015, 05:34 PM
EHarris's Avatar
Disconnecting battery now. Thank you.
Old 05-29-2015, 05:51 PM
EHarris's Avatar
I was only about 4 miles from home so I took it slow and got it to my place. Batter disconnected now. Keep the post updated
Old 05-29-2015, 06:03 PM
EHarris's Avatar
Disconnected battery. Let it sit for about 5 minutes. Re-connected. Lights still lit on dash.
Old 05-29-2015, 07:05 PM
Andy_PHA's Avatar
ABS pump locked up maybe? I'm trying to think of anything that could keep line pressure on the brakes.
Old 05-29-2015, 07:30 PM
EHarris's Avatar
I was thinking the e brake since I used it immediately before but I am not positive all 4 are locked. What would be an easy way right now to test which wheel is locked up?
Jack up the rear end, wheel chock the front wheels, put jk in neutral and see if tires spin easily?
I got the jk home to my place but I'm not super mechanical.
Old 05-29-2015, 07:57 PM
Andy_PHA's Avatar
In your original post you mentioned that all 4 rotors were overheated. I took this to mean all 4 brakes were exhibiting force on the rotors causing them to overheat as you drove. I would get all 4 wheels off the ground if you're going to do any testing just to be safe.
If in fact I misunderstood what you were saying, then yeah the e-brake certainly would be a suspect. The codes that you got would kind of point in that direction as well since it was telling you that the rear was the problem. Maybe it is stuck and because of all the errors the system was overloading the other brakes to try to compensate?
Old 05-29-2015, 08:54 PM
EHarris's Avatar
Sorry if there was any confusion. All four rotors were hot to touch. I stuck my finger through the wheel and they burnt my finger as soon as I would touch any of them.
I don't know for sure.
Quick Reply: Need help. Stuck on side of the road
