Sponsored by:
Sponsored by: DashLynx
Red light to the right of temp gauge
Old 12-19-2011, 03:25 AM
RonFDNY77's Avatar
Default Red light to the right of temp gauge
M driving and this Red light to the right of temp gauge started coming on and off then stayed off the temp gauge us dead center. What in the world is that light. 07 unlimited
Old 12-19-2011, 03:28 AM
RonFDNY77's Avatar
I would think warning light for temp but gauge is fine
Old 12-19-2011, 03:29 AM
RonFDNY77's Avatar
Old 12-19-2011, 03:39 AM
b.brewer's Avatar
Default Dumb Question
i know its redundant and almost insulting but did you check the owners manual, no offense intended but i had to ask.
Old 12-19-2011, 03:52 AM
Bucko's Avatar
self destruct warning lamp.
I'm downloading YOUR owners manual for free from the Jeep website...
(and no, the Jeep website did not used to be this helpful!)
Here's your answer.
17. Sentry Key/Security Alarm Indicator Light — If
Equipped
Refer to “Sentry Key Immobilizer System” or “Vehicle
Security Alarm” in Section 2 of this manual.
I rock!
Old 12-19-2011, 03:55 AM
Bucko's Avatar
page 16.
The Sentry Key Immobilizer System does not need to be
armed or activated. Operation of the system is automatic
regardless of whether or not the vehicle is locked or
unlocked. During normal operation, the “Security Alarm
System Indicator Light” will come on for 3 seconds
immediately after the ignition switch is turned on for a
bulb check. Afterwards, if the bulb remains on, this
indicates a malfunction in the electronics. If the bulb
begins to flash immediately after the ignition switch is
turned on, this indicates that an invalid key is being used
to start the vehicle. Both of these conditions will result in
the engine being shut down after 2 seconds of running.
Keep in mind that a key which has not been programmed
is also considered an invalid key even if it is cut to fit the
ignition for that vehicle.
If the “Security Alarm System Indicator Light” comes on
during normal vehicle operation (it has been running for
longer than 10 seconds) a fault has been detected in the
electronics and the vehicle should be serviced as soon as
possible.
*From me*
Make sure you don't have any carbon fiber or copper as in a keychain or anything like that. These two items do really well at blocking RF and like frequencies.
This happened once in my old Grand Cherokee. It shut off after 2 seconds of running but never happened again. I dont know if there is a battery in the transponder that can go bad or what ???
Old 12-19-2011, 03:58 AM
scononie's Avatar
This has happened to me recently too. The dealer wasn't able to retrieve any errors or codes from the Jeep. They said that the key may be going bad and to replace it soon. If the key goes bad, the Jeep won't start.
Good luck.
Old 12-19-2011, 04:01 AM
Bucko's Avatar
Good luck.
Just edited my last post.
I don't know anything techinical about the transponder in the key but i wouldnt want to get stranded because of something THAT stupid. It freaked me out but never happened after that (one other tiny reason to justify me buying my JK, lol).
Old 12-19-2011, 04:11 AM
RonFDNY77's Avatar
I knew I should have explained I didn't have access to manual. Rear seats folded down and it's under them. I have a couple hundred pounds of tools back there and a broken foot not allowing me to move them at the moment. I knew someone was gonna bust my chops lol. Soooooo they key! Ahhhh very good sir thank u much
Old 12-19-2011, 04:14 AM
RonFDNY77's Avatar
Not too worry I keep a spare key in the folder with the manual. ....... Doh!
Quick Reply: Red light to the right of temp gauge
