2026 Jeep Wrangler Quick-Release Door Hinges Are a Massive Convenience: Video
The new quick-release door hinges present on the 2026 Jeep Wrangler are very convenient and could help solve rust issues, too.
Since the beginning of time – er, Jeeps with removable doors at least – many owners have been keen to take advantage of that particular feature, which not many vehicles out there can offer. The modern day Jeep Wrangler utilizes special hinges to make that happen, which is both a good and bad thing – good in that it makes it pretty easy to remove those doors with basic tools, but bad because those hinges tend to corrode. However, new quick-release door hinges present on the 2026 Jeep Wrangler add even more convenience to that long-time feature.
In this recent video from the YouTube channel Jeeps on the Run, we get a look at these new and innovative door hinges present on the 2026 Jeep Wrangler. For the very first time in that model’s history, one doesn’t need tools to remove the doors – which is wild to think about, because it means that a brand new, fancy, high-tech SUV has doors that will be easier to remove than the ones on old vintage models – even with things like power door locks, windows, and other amenities.
Peeking inside, we can see that there’s still a door hatch that prevents the door from overextending, but now, there’s a clevis pin with a tab on the bottom. To remove it, one simply flips that tab upward, after which it comes right out. Then, you have to remove the same plastic panel and connectors for the aforementioned power items, as was previously the case. From there, it’s simply a matter of lifting up on the door to clear it from the hinge.
With the door removed, our host notes that it looks like everything that comes into contact with the door pin is painted, which should hopefully help rectify the rust issues present on existing models with the old design. It also looks like there’s a barrier between the hinge and the door, plus a little extra protection inside of the piece that it slides into. With the door removed, the connector does stick out a bit, however, and could be prone to picking up rock chips as a result.
In any event, this certainly looks like a big upgrade on the old design, and perhaps one that could help solve rust issues – or maybe at least cut down on them a bit. If nothing else, the fact that the 2026 Jeep Wrangler doors can be removed quickly and without the need for tools should make it pretty appealing to customers in this space, too.
You must be logged in to post a comment.
