Adding a Portable Rear Winch to Your Jeep Wrangler
Adding a rear winch to your Jeep Wrangler can be tough, but a forum member has come up with a great way to add a portable setup with the hitch assembly.
There are a great many options for adding a winch to the front of your Jeep Wrangler, but without making significant modifications, it isn’t quite as easy to add a winch to the back end. Fortunately, forum member “Rednroll“ put together a great DIY that illustrates how to use the rear hitch assembly to add a winch that can be stored in a small bag until you need it.
The Plan
When “Rednroll” introduced his portable rear winch setup, he explained why he came up with this idea:
“A while back I picked up a HF Badlands 2.5K winch open box item for $35 during one of their tent sales. The regular price is $78, but you can often find a coupon for it for $50. I figured for $35, what the heck I’ll find a use for it. Took it home, tried it out to make sure everything was there and was working and it all checked out.
I finally got around to figuring out a use for it. I already have a 12K winch mounted on the front in my AEV front bumper but was thinking having a smaller winch in the back could add some conveniences.
My intended uses are the following which I think this winch should be able to handle.
1. Hunting: Pulling a downed deer out of a field. They can get heavy and I’m not getting any younger.
2. Camping: Dragging large logs for camp fires.
3. Yard Work: Pulling brush and bushes
4. Winter: Pulling cars out of 12in+ snow/ice that often get stuck on the roads in my neighborhood before the road crew plows the roads.Of course most of this could be done with my front winch, but having something smaller for these smaller tasks seemed easier to manage, and less effort to wind it up and put it away.”
That intro post also detailed all of the items that he purchased to add the portable rear winch to his Jeep, with pictures of each item- all of which cost him just $135.
The Build
With his second post in the build thread, the OP explained how he built the portable winch rig, using a universal hitch receiver:
“The easy part was mounting the winch and fair lead on the hitch receiver winch mount. However, I decided that I also wanted the control box and fuse also mounted on the hitch receiver so it was a complete assembly that could just be connected to power.
I considered permanently mounting the control box and fuse to my JK but then considered I wanted this to be a portable winch setup where I could just connect the complete assembly to a battery. As well, this would likely prolong the life of the control box not having it constantly being exposed to the elements if permanently mounted on the outside of my JK.”
Finally, he explained how he tested the portable rear winch setup:
“I tested it out by putting my JKU in Neutral and setting the parking brake and did this to wind the rope onto the winch with tension on the rope. I did a snatch block double pull setup and a single pull setup without the snatch block and the winch pulled my JKU with ease.”
Of course, there are far more details and images in the build thread, so if you are looking for an innovative way to add a removable/portable rear winch to your Jeep Wrangler, click here to check out the DIY thread.
