JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Recommendation for Tire Deflator?
Old 02-14-2015, 09:35 AM
cedarraider's Avatar
I'm looking into the ones from barricade they are $30. Not sure of how accurate they are but if they can get me close it will be good enough.
Old 02-14-2015, 09:40 AM
GutlessPhred's Avatar
Originally Posted by dmwil
Is it true you can put the tire guage right on these without taking them off?
Yes. That's what I do. I put all four on then by checking them I just put the gauge right on the deflator. Works great. After you use them a few times, you're able to figure out about how long it takes.
Old 02-14-2015, 05:30 PM
MB_Pathfinder's Avatar
I like my Currie E-Z Deflator - http://www.4wd.com/Jeep-Wheels-Jeep-...pn=CURCE-9029E)
Old 02-14-2015, 05:46 PM
Billbikes's Avatar
I also use the ARB. Never had a problem with screwing up the threads on the core. Does a pretty quick job. I do carry spare valve stems and cores just in case though....
Old 02-14-2015, 06:33 PM
lowendrider's Avatar
X2 on the Currie...appears to be the same as the ARB only slightly less $$. Makes quick work of airing down, easy to use and keep track of PSI.
Old 02-14-2015, 06:52 PM
JK Forum Regional Rep
familytime's Avatar
Been using the brass style ones from rugged ridge,gets my tires down to 6psi.Works great
Old 02-15-2015, 04:25 AM
dmwil's Avatar
How easy is it to adjust them to a specific pressure and keep them there?
Old 02-15-2015, 04:28 AM
dmwil's Avatar
Originally Posted by MB_Pathfinder
This one is looking better, pricewise, for sure, except with shipping, it will still get close to $40, which is more than I want to spend. I'm still leaning toward the brass though, if they are easy to adjust and bring the pressure down consistently and accurately, every time. It is looking like this is the way to go, for speed, though. I'll be tuning them for 20lbs for most situations, and probably 15 for slower, more technical situations, like rock crawling, so adjustability has to be easy.
Edit: The Curry just got a boost, as I saw there is free shipping at 4wd Hardware. I'm now leaning that way. $30 is still steep, so I'm waiting to hear back from the brass users to see how accurate and easy to adjust they are.
Old 02-16-2015, 06:10 AM
GJeep's Avatar
It's easy to adjust them, a little bit of patience is all it takes.
None of the Staun-type deflators, including the Staun itself, can be counted on to keep the adjustment, but there's a simple cure -- a drop of Locktite on the threading.
Another interesting option, expensive, but with multiple pressure options - you just push and rotate to set a desired psi.
This one has the range of 10, 12, 14, 16, 18 or 20 psi :
Name:	Tires - Air Deflators 233 - resized.jpg
ID:	597012 Click image for larger version
Name:	Air Deflators 002.jpg
ID:	597013 Click image for larger version
Name:	Tires - Air Deflators 234 - resized.jpg
Old 02-16-2015, 07:06 AM
Vladimer's Avatar
Originally Posted by Tooadvanced
I have the ARB one that pulls the stem. Impossible to lose the stem as you screw on the connector then remove stem so it is trapped inside the tool. I can air all my tires from 30 to 12 psi and someone else's jeep the same before my brother staun type deflates his tires.
His deflators must be crappy knock offs, I have the staun II's and no way anyone with an arb deflator comes even close.
Here is a good test for anyone considering getting them (or another brand)
https://www.youtube.com/watch?v=9XtZ1QOP9Pg
Quick Reply: Recommendation for Tire Deflator?
