Recommendation for Tire Deflator?
I like my Currie E-Z Deflator - Currie Part CE-9029E - E-Z Tire Deflator - 4 Wheel Drive)
Edit: The Curry just got a boost, as I saw there is free shipping at 4wd Hardware. I'm now leaning that way. $30 is still steep, so I'm waiting to hear back from the brass users to see how accurate and easy to adjust they are.
None of the Staun-type deflators, including the Staun itself, can be counted on to keep the adjustment, but there's a simple cure -- a drop of Locktite on the threading.
Another interesting option, expensive, but with multiple pressure options - you just push and rotate to set a desired psi.
This one has the range of 10, 12, 14, 16, 18 or 20 psi :
I have the ARB one that pulls the stem. Impossible to lose the stem as you screw on the connector then remove stem so it is trapped inside the tool. I can air all my tires from 30 to 12 psi and someone else's jeep the same before my brother staun type deflates his tires.
Here is a good test for anyone considering getting them (or another brand)
https://www.youtube.com/watch?v=9XtZ1QOP9Pg
