Archived - Jeep XJ Cherokee & Grand Cherokees Discuss the Jeep XJ Cherokee and Grand Cherokee at our sister community. This includes all Jeep XJ's made between 1984-2001 and all Grand Cherokees made to this date.
95xj starting issues
Old 03-25-2010, 04:53 PM
DJjeep's Avatar
Default 95xj starting issues
I just bought a 95xj. The guy I bought it from says after its hot sometimes it doesn't want to start back up. If you let it cool down 10-15 minutes it starts right up. It ran great when I drove it, and it started back up a few times after. I was wondering if any one else had this issue, or thoughts on where to start looking?
thanks for any help
DJjeep is offline
Old 04-01-2010, 08:16 PM
usnfoley13's Avatar
this sounds like a possible heat soak of one of the fuel injectors, i remember it is the #3 or #5 cylinder. this was actually a recall and the fix was extra heat shield around that injector.
usnfoley13 is offline
Old 04-02-2010, 02:13 PM
ronjenx's Avatar
On the earlier XJ's, I seem to recall the crank position sensor would sometimes keep a hot engine from starting.
ronjenx is offline
Old 04-03-2010, 03:38 AM
98XJSport's Avatar
Hot CPS is a common problem that will shut an XJ down and let it restart when it cools.
98XJSport is offline
Old 04-04-2010, 11:49 AM
DJjeep's Avatar
thanks for help, I will be checking the heat shield and the cps
DJjeep is offline
Old 07-06-2010, 12:03 PM
DJjeep's Avatar
Turns out it was the ignition switch and the key cylinder were bad, not making a good connection. $150 and were back in business
DJjeep is offline
Quick Reply: 95xj starting issues
