Boating & Fishing General discussion forum regarding all forms of boating including motor boats, sailboats and all things fishing including fly fishing, deep sea fishing, fishing gear and great places to fish.
battery issue - PWC
Old May 15, 2009 | 05:17 AM
07JKX's Avatar
Default battery issue - PWC
So i had some bad cavitation... replaced the impellar and housing and the "slipping transmission" feeling has been corrected unless i try to go from a stop to a full throttle
HOWEVER... after about 1.5 minutes of cruising at approx. 40 MPH, it just shuts off.:confused:
i thought my battery cable came loose and when i reached down to check, I got a lovely 3rd degree burn off the positive terminal. negative was luke warm, but positive had to be several hundred degrees.
what could cause the battery to do this??? bad battery? overcharged? it is a standard acid based battery.
Old May 15, 2009 | 05:55 AM
InTheMist's Avatar
Was the post tight?
Battery or alternator is my first thought. The battery should supply a LOT of current before getting hot - if the post connection is tight.
Battery is cheap and easy and you can even borrow from someone else to try it out first - or even borrow it from your Jeep.
Is it one of those screw terminals or an automotive style clamp on thing?
Old May 15, 2009 | 06:03 AM
07JKX's Avatar
the jet ski takes the smaller battery... the ones you fill up with acid and then charge. My thumb hurts... and i have a flat head screw and bolt pattern burned into the skin. lol
Old Jan 27, 2010 | 09:10 AM
Yellow93's Avatar
Sounds like the wrong size battery....
