Pullin' the BIG PIG..
Again, "Risk" has its allure, and if you are the only one at risk, your decision; how ever, if Murphy's Law takes over, and you "risk" other people and property, you are being stupid and selfish to prove an ego-point. And despite what Mr. Insurance Man says a few posts back, you better read the "fine print" on your insurance policy, and have a clear understanding of "reckless endangerment"
Finally got brave enough to try my rig as well. The boat is a 2001 24' 5.7L Deckboat weighing in around 5500lbs wet weight. Took the jeep for a spin around the neighborhood to try her out, and was really impressed. As reference, I have been towing boats since I could drive. The Jeep had plenty of power for pulling and stopping below 35mph. Very similar to the 4.6L F150 I use as my tow vehicle. As my bravery increased, I loaded the jeep up with five friends, and the boat and headed to the lake. This is where the story changed a bit. With the extra weight in the jeep, I felt a change in her handling. The back end felt a bit loose when my speed increased to around 50mph (downhill only). In my ten mile drive to the lake, I drive down a moderately hilly two lane country road. The speed limit is 45mph, I would try to get around 50-55mph at the top of hills to assist the jeep in getting past the upcoming hill. I also found drive 2 also helped in the lower speed range going up hill. As for the jeeps power at the lake ramp, no problem. My lake ramp is a bit steeper so the back wheels barely got wet when backing up. One problem I found was that I couldn't see anything when backing the boat down the ramp. I turned around and all I saw was boat...not what I'm used to when using the f150. Took me a bit longer to put the boat in the water using the side mirrors. I guess Chrysler didn't intend for people to have much of a view when looking backwards.
All in all, its is possible, but I felt like it was a lot less work using the truck.
Cool, nice job, sounds like you took it a little faster than I would have.
FYI, I was towing a 10' trailer with two dirt bikes and a bunch of gear a couple of years ago going pretty fast on a twisty two lane and broke my track bar going around a tight curve. Take it real easy and all is good.
