Central Canada If you live in the Ontario or Quebec area of Canada and would like to meet some of the great JK-Forum members near to you and/or discuss upcoming trail events, this is the forum for you.
Block heater
Old Feb 15, 2015 | 08:30 AM
hipfan39's Avatar
Default Block heater
Have a 2007, can't find my block heater cable! Any ideas? I thought it was by the battery and fuse box.
Old Feb 15, 2015 | 08:50 AM
ronjenx's Avatar
That's where it usually is.
Is this a new to you JK?
Old Feb 15, 2015 | 09:31 AM
bevan7170's Avatar
I had one fitted in the summer. Life saver. I have the end run the the front crossmember coming out by the drivers side tire.
Old Feb 15, 2015 | 09:58 AM
hipfan39's Avatar
Originally Posted by ronjenx
That's where it usually is. Is this a new to you JK?
No it's a 2007!
Old Feb 15, 2015 | 10:02 AM
ronjenx's Avatar
Originally Posted by hipfan39
No it's a 2007!
Yeah, I know it's a 2007. I was wondering if it's new to you, so I would know whether or not to ask if you have seen the cord in the past.
Old Feb 15, 2015 | 02:05 PM
scratchkenny's Avatar
I have a 2013 JKUR I found my plug tucked into the right side of the radiator and wheel wheel.
Old Feb 15, 2015 | 04:40 PM
bevan7170's Avatar
If you really want to look for it grab a flashlight and scoot under the engine. Look on the passenger side. On the side of the engine above the sump. Then trace the cable, if there is one out.
Old Feb 15, 2015 | 04:54 PM
webejeepin's Avatar
Like others have said between the battery and fuse block. If you have never used it before it could be zip tied and tucked a way down. I have an 08 that's were I found mine amongst other black cable loam just look for it. Life saver for sure right now I have mine on a outdoor timer.
Old Feb 15, 2015 | 05:31 PM
ybugly's Avatar
Just curious is this an option or do all have them?
Old Feb 15, 2015 | 05:38 PM
bevan7170's Avatar
If you have you build sheet look on that. If not look under the hood.
