Central Canada If you live in the Ontario or Quebec area of Canada and would like to meet some of the great JK-Forum members near to you and/or discuss upcoming trail events, this is the forum for you.
Figured out my noisey Tranny issue
Old Nov 7, 2008 | 06:22 PM
whtIwrk4's Avatar
Default Figured out my noisey Tranny issue
I've noticed in the last little while that my tranny has been a bit noisey. Started getting a little noisier when it gets really cold. Never really thought too much about it. I remember taking Waynes Jeep for a ride after lifting it a few months ago that it shifted and sounded smoother than mine, but again, I paid it no mind. It wasn't until I went to grab some lunch with my buddy from work that changed things. We were driving along and he commented that my tranny was noisey, and then I really started listening. Everything looked nomal and the oil was clean. You could here it in neutral and when the clutch was pressed it went away, like marbles rolling around. Going down the road you could really hear the tranny.
I debated taking it to the dealer for warranty, but didn't feel like getting the runaround. I changed the oil to a synthetic ATF spec'd for mercedes and other high end transmissions and it was only marginally better, although it shifted ALOT smoother.
Finally, I found a post on another forum where a guy said that his inner boot had come loose. I put 2+2 together and figured that this must be the problem. Abut 8 or 9 months ago I had the clutch and throw out bearing TSB done. I realize now that it started around that time. When the guy pulled the tranny, he must have left the boot off,or not installed it correctly.
Tonight I removed the shifter knob and upper boot and sure enough, the inner boot is just flopping around down there, not clipped in. I has four clips to hold it down and one of mine is broken off. It also has a rip in it. To see if it would cure my problem, I duct taped the rip and installed the boot properly. The difference is like night and day. I can hardly hear the trans now in neutral and I barely hear it while driving. the guy at the dealer cut some corners to get my tranny out and didn't properly disconnect everything up top before lowering the tranny. It happens like this because those guys are on a flat rate system and they are already losing money doing a warranty job, because their hours are cut down. I used to work at a dealership, that's how I know this. It's hard for me to blame him, because the system is designed that way. Sad.
Anyway, tomorrow I'm going to the dealer to order a new inner boot. Just thought I'd write this to give anyone else with a noisey tranny an Idea what to look for. Just may be an easy fix like mine.
Cheers
Old Nov 7, 2008 | 06:45 PM
Piginajeep's Avatar
yeah, my dealer fucked mine up too. it helped fixing the boot but the tranny still sounded like pop cans. Kinda like Todds.
No problems with the new one.
Old Nov 8, 2008 | 05:33 AM
zeero's Avatar
Yeah those noisey Trannies can be a real ear AND eye sore....
Glad you got it sorted it out!
Old Nov 8, 2008 | 05:36 AM
WRAITHYJEEP's Avatar
gag ball todd has lots of them
Old Nov 8, 2008 | 05:40 AM
seriously though
that sux
and i'm not surprised by the dealer either
did you just pop the top shifter boot off on the console and look down and see it was off?
Old Nov 8, 2008 | 05:44 AM
i know mine was on right last monday i changed my fluid and ya it was dirty well not as clean as it could be with 40,000kms on it, I was having 1 to second gear clash more so than normal, i made 2 special tools to fit the drain plugs and I put new mopar fluid in 12$ a pint, ps it is synthetic. i used there fluid so that i have a record that i changed it with a receipt for the fluid. (just to cya)
anyhow... post change a a week later everything works much better now.
Old Nov 8, 2008 | 09:26 AM
-MAW-'s Avatar
BUT DID IT FIX THE CHIRP WHEN YOU SHIFT ??
Old Nov 8, 2008 | 11:04 AM
whtIwrk4's Avatar
Originally Posted by WRAITHYJEEP
seriously though
that sux
Ya, just removed the top shifter boot and bingo. The bezel that hold the top boot is very easy to break, so be careful if your going to remove it. Broke mine once before and also broke Todd's buddy's inthe parking lot at Rausch by accident while we were trying to install his CB. (sorry again) Good news is they are cheap to replace.
Ordered the inner boot today for about $15. Not bad, could have been worse.
Old Nov 8, 2008 | 01:27 PM
JKDad's Avatar
I myself didn't notice anything wrong with the pictures. Until I look really closely and realized that it was a bottle of Vanilla Coke. I can only handle so much freaky, and then I really have to draw the line.
I think that there is a rule on these forums about advertising or such, no more softdrink adds plz, at certainly not for Vanilla coke, wtf...
This is a Canadian forum, out with the soft drinks, in with the beer...
Cheers
JKDad
Old Nov 8, 2008 | 02:12 PM
Cheers
JKDad
ya that's it, thats what is wrong, vanilla coke,
